Old 11-19-2013, 02:54 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Hi everyone.
I need advise we installed a 2jzgte motor in an e46 M3 but it's not making power as soon as it gets to 5800 RPM the power drops.
List of mods done.
Running a powermod ecu
Stock bottom..gasflowed head,cams cut same place as mine split duration 268 ex and 272 intake.
Turbo T72 .68 Exh Turbonetics. Same Exh manifold as mine cheap.
Turbosmart wastage 45mm..
50 mm dump valve.
Fake Greddy intake manifold.80mm throttle.
750cc injectors.
Cometic low comp gasket with arp studs.
76mm downpipe with 76mm Exh.
It made like 240kw and 400nm something is wrong....?????????
Can you post a dyno run with air-fuel and boost plotted together with horsepower and torque?
Life begins at 30psi.
