Old 11-19-2013, 11:27 PM   #1
gorillaguy8
gorillaguy8's Avatar
gorillaguy8 is on a distinguished road
Default Solid Brake lines
Does anybody know of a place I can buy new solid steel brake lines? I had a section of the rear brake line after the T above the rear diff rust away. Ive decided to replace everything going from the first coupler (next to the bell housing) all the way back. The long tube that runs along the floor and up above the diff doesnt look too complicated and I should be able to use my bender to make that piece. The ones from the T, that go to each wheel have small bends in them and would be hard to make. Ive searched google with no luck. I guess i could call the dealer and see if the have these.
Black 87 N/A, re-built from the ground up.
gorillaguy8 is offline   Reply With Quote
