12-06-2013, 09:11 PM
#12
Supra Owner
Originally Posted by normalsalaryman
talking about Avgas been wondering if you know much about that stuff, most of the people backhome has been saying avgas has same number of octane as the vp, BUT i did try once it does no different in term of acceleration, but my engine temperature is raising rapidly..almost twice hotter than a vp fuel. and somehow my idle is higher than normal it does when im running on vp fuel...on an NA engine
i dont know if avgas act like that or if you ever try and experience different..
Yep that's consistent. The very cold air in high altitudes is also a factor in how avgas is formulated. Please stick with VP fuel or methanol injection or E85 to eliminate detonation when using the 2jz-gte at high boost.
Life begins at 30psi.
