Originally Posted by cre
Every part you're having trouble with requires a speed signal from the speedometer. Find which section of the speedometer cable is broken and replace it. It runs from the passenger side of the transmission up along the firewall and through the firewall at the rear of the engine.
Ok so the speedometer works but the speed it reads is slightly off. Should I grab a speedo cable and a speed sensor?
