Old 02-02-2014, 05:00 PM   #5
Scraperondubz
Scraperondubz is on a distinguished road
Originally Posted by interested! View Post
Hi! , You said the Transmission level is good , - Question ? , did you check this while the engine was running ? , the fluid is taken from the sump and enters the torque converter giving a lower reading than if checked with the engine stopped . Also take into consideration HOT and COLD reading levels .
Yes I checked fluid while car was running and at operating temperature
Scraperondubz is offline   Reply With Quote
