You'll need a driveshaft to match whatever transmission you decide to use. If you're using a manual transmission you'll need a 1JZ bell housing for that transmission. You'll need a good amount of wire to extend the harness. I can't recall, but if you just use the adapters (sold by DriftMotion) instead of swapping the cross member and mounts for 89+ parts you may need a different oil pan.
