Originally Posted by Schrom
probably 18's or 19's i think im gonna go try to get XXR 521's.. don't know what size tires though or if i need to roll my fenders or anything.
and whp sorry.. don't know cheapest but most reliable way to obtain that really.. i found a recommended place in AZ to take my supra too, they specialize in Japanese cars so i'm gonna check it out soon.
The main consderation on the rims is the
width, not the diameter. More HP = more width. For 350rwhp, you'll need at least 275s. For 550rwhp you'll need at least 315s. Anything above 700rwhp you'll need at least 335s.
To fit 315s you'll need to trim (not roll) your rear inner fender lips. Rolling enough to get the clearance you need will distort (bend) the fender. Trimming is quite easy with a reciprocating saw. Trim, grind smooth, paint. It only takes about 30 minutes a side, and results are 1) perfect, and 2) no downside whatsoever - the fender retains all of its strength.
The stock exhaust will handle about 500rwhp with no problem. In my experience, if you're doing exhaust as one of your first upgrades, it's mainly for looks and sound...not performance.
The need for brake and suspension upgrades depends on your application. If you can swap in TT brakes, it'll be more than you'll ever need for daily driving (even 'spirited') daily driving. If you're planning on roadracing, you'll want to look into suspension upgrades. If you let us know more about exactly what you want to do with your Supra, we can provide you with more specific advice.
