Originally Posted by wildman103
I just finished swapping out my car with a GTE and i bought all compatible parts, when i go to start my car theres no spark, not even a faint spark from any cylinders, i ruled out coil packs and cam sensor because there completely new, the coil pack ground is new and secure all my grounds are clean and tight and I've tested all of them im starting to lose my mind, i tried the trick of spinning the cam sensor and didnt hear anything or see any spark, and i checked the voltages to the coil packs and igniter and have 12V where needed, i just purchased another igniter, only to see if thats the problem, but when i turn the key to the on position my engine light doesnt come one, and when the 7mge was running it did, is that a sign of ecu problems, because i tested all ECU voltages from the online TSRM and there all where they need to be, and i have i couple of wire ends behind my dash that i have no clue where they go, ones red with black spots ones orange and green with black spots and the last is blue with red line, any help thanks
Are you using the TSRM? You should have both the 'Engine' and the 'Electrical' TSRMs handy for the project you're attempting...
I'd suggest starting with the ignition
troubleshooting section of the Engine TSRM. Oh, check the Electrical TSRM for the colors of the wires you've got hanging behind the dash too.
Here's a starting point:
http://www.supracentral.com/foundation/mkiv-tsrm/
http://myweb.usf.edu/~cbmurphe/95tsrm.rar
http://www.qoke.net/supra/95tsrm.rar
http://www.2jzgarage.com/2012/01/97-...ervice-manual/
Here are the Toyota part numbers (there's no substitute to having the book right next to your car):
1993.5
00400-RM343-U1 VOL 1 REPAIR
00400-RM343-U2 VOL 2 REPAIR
00400-RM347 ATM OVERHAUL
00400-WD174 COLOR WIRE DIAGRAMS
00400-14500 OWNERS MANUEL
1994
00400-RM359-U1 VOL 1 REPAIR
00400-RM359-U2 VOL 2 REPAIR
00400-RM391 ATM OVERHAUL
00400-WD182 COLOR WIRE DIAGRAMS
00400-14507 OWNERS MANUEL
1995
00400-RM408-U1 VOL 1 REPAIR
00400-RM408-U2 VOL 2 REPAIR
00400-WD219 COLOR WIRE DIAGRAMS
00400-14514 OWNERS MANUEL
1996
00400-RM444 REPAIR
00400-RM481 REPAIR SUPPLEMENT
00400-WD253 COLOR WIRE DIAGRAMS
00400-14523 OWNER MANUEL
1997
00400-RM502 REPAIR
00400-WD274 COLOR WIRE DIAGRAMS
00400-14525 OWNERS MANUEL
1998
00400-RM587-U1 VOL 1 REPAIR
00400-RM587-U2 VOL 2 REPAIR
00400-EWD326U COLOR WIRE DIAGRAMS
00400-OM14528U OWNER MANUEL
OTHER BOOKS OF INTREST:
00400-NC096 NEW CAR FEATURES 93.5 SUPRA{EXCELLENT}
00400-NC109 NEW CAR FEATURES 1995
00400-NC120 NEW CAR FEATURES 1996
00400-NC132 NEW CAR FEATURES 1997
00400-NCF150U NEW CAR FEATURES 1998
00400-BRO42 COLLISION REPAIR MKIV
00400-RM767E WIRE HARNESS PLUG AND TERMINAL BOOK
