I thought the ECU monitors three signals as a part of the equation you're talking about: IGt, IGf and IG- Unless they're all screwing up in harmony a code is bound to show up.... I could be wrong completely wrong though, I haven't had the pleasure of working with a TCCS where simply swapping out components as a last ditch effort didn't cure it. I would replace the wires along with the connectors. Corroded wire has a higher resistance too.
