I know it's late but did you get this sorted out? There are two fusible links which are likely to be the cause. One's in the engine bay fuse box on the left, on earlier models it just looks like a wire. and the other is a segment of wire that's patched into the cable between the alternator and battery.
Tip Jar ---> ![](https://www.paypalobjects.com/en_US/i/btn/btn_donateCC_LG.gif)
