Originally Posted by Moosemkiii
Hey there so I have a 1987 supra it's acting out in a weird way it will start and turn over but the odd time it will won't at all but the dash lights come on. I have replaced the starter I thought it could've been a dead spot which the old one did have and after I put the new one in it started first try but after I got home from my buddy's garage it acted out again but I tried it again today and started no problem but I know it's going to happen again any ideas
It's a common problem with the MkIII, not enough voltage going to the starter through the ignition wiring. You can work around it as Interested says, but it's just that, a work-around. I've got the exact same issue in my '88, and have somewhat isolated it to the wiring near the ignition switch. Haven't locked it down yet, and am forced to use a HD relay and momentary switch to get by until I really figure it out.
