Your 3 trouble codes all seem to be pointing to the AFM or its wiring. You can check the wiring by measuring the resistance (or continuity) of each wire from the AFM connector to the ECU connector. If you have little to none resistance then the wiring is most likely okay. Also you should test your AFM as suggested earlier, or at least swap out with a known good one if that's an option.
