Old 10-05-2014, 01:52 PM   #186
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
So im busy installing power mod ecu in my car did the turbos thrust again. wil let everyone know as soon as im finished with it and it was on the dyno.
also adding 2 ekstra breathers on the cam cover for the ekstra boost in case
Generally, a sealed PCV system is recommended over breathers. Run all PCV ports to a catch-can, and then run the catch can to a vacuum source (either pre-turbo, or post turbo with a one-way check valve). There's also a way to run PCV to the exhaust:
http://static.summitracing.com/globa...1189_US_xl.jpg
Life begins at 30psi.
