I think extra connectors under the intake manifold is normal, they could be for the different transmission options/abs/etc. I don't immediately recognize those ones in particular.
Were you able to find a different AFM and see if that made any difference? As far as testing the wiring to the sensor, I would get a look at the wiring diagrams and check continuity of each of the AFM wires between each end an make sure there are no breakes or unusually high resistance.
