Old 11-13-2014, 03:25 AM   #1
Joe1234
Joe1234 is on a distinguished road
Default Overheating issue
Hey guys. I need a little help and need some opinions before I start ripping this 7mgte apart. The engine Is having an overheating issue and I have no idea whats causing it. The engine only overheats when I use boost, and I'm not talking about flooring it, im just talking about maybe using 1 or 2 pounds of boost, but if I drive under 2500rpm it doesn't overheat. I'm assuming maybe the head gasket could be leaking but not exactly cracked yet? Maybe it's loose and I just need to tighten it? I wana make sure before I start digging in there. Thanks guys
Joe1234 is offline   Reply With Quote
