Old 11-13-2014, 09:25 PM   #4
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
When its a blown head gasket (or a cracked head) to the cooling system the symptoms are that after driving and shutting down the engine you hear a lot of sounds from the radiator cap and the over flow tank fills up and overflows onto the ground. Do you see a puff of white smoke on first start up in the morning? White smoke is usually coolant. Grey blue smoke is oil.
