Old 01-31-2015, 04:59 AM   #10
suprajim
suprajim is on a distinguished road
You only need to leave it out for 30-60 seconds to clear the codes and reset the ECU. You can take it for a drive and check for codes again. Fix these codes first and also check for boost leaks. The hose coming from the bottom of the turbo and the coupler right at the throttle body and 3000 pipe are two common leak locations that can be hard to spot. You say full boost, but what PSI are you hitting? Stock boost gauge?
1992 Supra 7MGTE A/T w/Sunroof Super Red/Shadow Gray
suprajim is offline   Reply With Quote
