Thread: Oil leak
Old 03-23-2015, 04:32 AM   #13
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Just do a google search for no. 3 cylinder cover. Prices are $46 - $48 for a new one with its plastic coating over the metal. The plastic coating tends to degrade over time. You will need a Hex socket to remove the 3 plugs. Harbor Freight has a good set for cheap. I think its a 14mm. I always add a bit of Permatex Black Ultra silicone to the threads of the hole and the plug before laying the no. 3 cylinder cover on. Tighten it down securely. This tends to be a leak problem area as are the valve cover gaskets where I use Black Ultra as well. I can offer you a used no. 3 cylinder cover without the plastic coating painted black for $10 plus $7 shipping. Just send me a private message.
