Oil is coming out of the intercooler pipes at the couplers? That's a boost leak. Since oil is thicker than air, if oil is leaking air is definitely leaking. That's probably your lack of power and boost. That is also most likely your vacuum leak causing your rough idle, unless you've fixed that already.
I still don't believe your problem is a tune, your car is not significantly drawing any more air in at idle than it was before. Your problems (to me) seem more likely to be a vacuum/boost leak, which it seems you have confirmed oil seeping. To answer your question, you do not need any additional bracing to stop your pipes from leaking. I have the generic intercooler kit you see all over eBay with the 2.5" hard pipes, and I have nothing supporting them other than what they attach to. It took awhile, but after tightening them several times after running the car, I was finally able to seal the connections and no longer have vacuum/boost leaks.
The oil leaking into your pipes may likely be from a bad seal in the turbo or possibly oil from the pcv system.
