Old 06-29-2015, 11:55 PM   #1
BudCallaghan
BudCallaghan is on a distinguished road
Default Plastic cover on rear window trim
I have three Supras, an '85, an '88 and a '91. The two MK III's have a plastic coating on the rear window trim. The plastic has separated in places and is quite unsightly. I have asked at several body shops about removing the trim to remove the remaining plastic and then painting the trim. However no one could determine how to remove the trim and suggested leaving it in place to do the job. Surely someone on this forum has had or is having this problem. I will appreciated information leading to a solution.
BudCallaghan is offline   Reply With Quote
