So first off are you determining the 3psi reading from the stock gauge, or an aftermarket one? So it looks like you checked all the basic diagnostics as leaks and vacuum hoses, you didn't mention it but double check your intercooler piping too, b/c that can add to your problem. And if all that checks out then I would probably suggest inspecting your exhaust pipings, cause if it's clogged/backed up at all then that could create back pressure. And after that it just might be a bad wastegate and etc... Hope this helps!
1989 Toyota Supra Turbo w/ Targa Top
White Exterior-Blue Interior
3" Blitz Catback Exhaust System
BIC Divorced Downpipe, Straight Pipe
Megan Track Coilovers
Apexi BOV, Turbo Timer, and Intake
Lexus Projector Fogs
Bride Low Max Replica
