Old 04-25-2016, 11:55 PM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
If the over flow tank over flows onto the ground after shutdown, could be the head gasket going. Check the there is no air in the system and that the fluid is drawn back into the radiator when cooled. I had the hose at the radiator develop a air leak that prevented the normal fluid drawback. If you want to check the block thermostat, take it out and heat it to boiling in water. It should be fully open by 190 deg F. Water boils at 212 F. The little jiggle valve goes up when installing. Be careful not the over tighten the 2 screws (or use ones that are too long), the aluminum in the head strips easily. I use a thin layer of silicone as well here. Antifreeze should be 50/50 to 70/30 (antifreeze/water) using distilled water to dilute when 100% concentrate is used. Floating ball testers can be helpful to test what you have in the system now. Never use tap water. Walmart has distilled water for 63 cents a gallon.
