Hello yet again allknowing supra mechanic. (hope you can handle my poor english
Started my car and all was well, after a rather embarrassing stop due to my somewhat unforgiving cluth I wasn't able to start up again. I could hear the starter turning and the engine almost getting to start and i could also smell an abundance of fuel from the exhaust.
About an hour later and still no progress I finally had a friend come help me push it and as a last try we tried "pushstarting" it and to my suprise it actually started. However when i returned home i noticed that i ran awfully having low idle down at 4-500 rpms and sounds like not running on all cylinders (just a guess tho).
The has new sparkplug leads and sparkplugs gappad at 0.8mm (bcpr7es). It dosent really have any mods other than 3inch from the turbo and back.
I did a boost leak test the day before this and i think i managed to tighten all the leaks /
had an overboost problem right before that which i solved by fixing these boostleaks /
Also the tps was recently replaced and calibrated after tsrm.
Have annyone had this type of problem before?
gratefull for all your answears.
