Antilock light dilema ends, Tail light sensor
Thanks again to this forum for helping.
I finally correctly jumped the diagnostic block and found 0 codes about my antilock light staying on and disableing my TEMS and cruise control.
On to another issue, I will get back to this one, NO FLIPPIN BRAKE LIGHTS NOW.
The light out warning light on my dash is on. ARE YOU KIDDING ME!
I remove all the plastic and rear seat to chase the wires from the door sill to the tail lights.
No frays and I have power up to the tail lamp failure sensor box mounted below the drivers side tail light.
I press on the connection and my. brake lights work again. Anti lock light still on though.
Out driving and the lamp out signal comes on again. Wiggling the connection at the box doesnt work.
I find a write up about how that sensor box stops working because of its location to possible water dripping in.
It says how to bypass the box by splicing wires.
TAIL LIGHT bypass connect green and the green with red stripe before the box
BRAKE LIGHT BYPASS conect green w/ white stripe to red w/ blue stripe.
SET THE BOX ON YOUR SHELF OR TOSS IT.
Cant hurt so I do that.
BAMM. Light out signal gone AND MY ANTILOCK LIGHT AND TEMS AND CRUISE CONTROL ARE ALL WORKING FINE.
Thanks again to all.
88 turbo targa-kn intake- 3" exhaust no cats- shrt shift mod- valve job and head gasket-heater core,
Eibach and tokico suspension, K&N intake
