Old 08-24-2016, 08:31 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by moggy View Post
Hi all,
My mk4 Supra is collecting dust in the garage.
when I start her up she runs fine.then after a few minutes she starts to run lumpy.I'm I'm guessing here... its like it starts with auto choke and runs fine... then when the choke goes off it runs lumpy....
any thoughts on the problem it has???
cheers
moggy
Check for boost/vacuum leaks. You could also try cleaning the injectors and changing the fuel filters. Those are the basics...if you get that all done and it's still lumpy, please check back.
Life begins at 30psi.
