Old 03-10-2017, 01:54 AM   #1
Vacationtime247
Default 1987 Toyota Supra 350 Chevy V8 / 700R4 race car
$2200 obo Sadly I'm selling my Supra. List of mods are below. Worth way more than asking price. Fun and very fast! Drift car or drag race. Would have plenty of clearance to install an LS type engine or leave it as is.
1987 Toyota Supra solid top / no targa
Less than 100k on the Odometer, title last OD 55,298 miles
3.73 rear LSD gear swap
Headers into side pipes.
B & M Racing 4 speed shifter with custom welded mounting brackets
700R4 with B & M racing shift kit
B & M 2400 RPM stall converter
Dual transmission coolers with electric fan
Custom rear transmission mounts
1/4 welded steel plates and solid motor mounts
350 Chevy Vortec roller engine
Vortec heads with machine cut valve guides to allow additional lift
LT 4 Valve springs
Crane Roller rocker arms
Chevy HOT roller cam .525" lift I & E
Poly locks for Rocker arms
Edelbrock 750 CFM carburetor
Edelbrock Performer RPM Vortec Intake
Big End High Flow electric fuel pump
High flow electric fan
Custom Aluminum radiator (from an old RX7 swap / build)
Short water pump and accessories
Grant GT steering wheel
Tachometer, Oil pressure, Volt & Temp gauge, fan / relay switch
MSD electronic ignition (an RPM rev limiter box can be added)
HEI distributor with MSD
Custom length driveshaft (90% chevy with a flange and toyota rear welded then balanced)
Brand new front windshield
Located in Muncie, IN
Email me at vacationtime247@aol.com with questions
