Originally Posted by btwilson86
As far as I know, the transmission wire connections are the same (as long as you're sticking with the same transmission; a340e, w58, r154). I can't say that with 100% certainty, but I can't say I've come across any transmissions that didn't connect to the wiring harness correctly.
Just wanted to follow up with you on this, as there is indeed no wiring difference that I could find. Plugs right in. Now, the extension housing (tailshaft housing) is different as the speedometer plug is on the opposite sides of the housing, and the shift rod is different, but wiring is the same.
