Old 05-22-2018, 02:14 PM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
There should be a vacuum line picture diagram under the hood. Non-US cars did not have EGR vacuum lines I believe. If your car is right hand drive, the hearer hose route around the block could be a little different.
The attached pictures may be helpful. It doesn't clearly show the route of the blow off valve line though. I think later Supras dropped the power steering vacuum assist line also. There is a vacuum nipple that comes out of the backside of the intake manifold that feeds a T connection on the firewall for the heater and cruise control.
Hope this helps you get started.
Bru
Name:	supra cooling system.jpg
ID:	4997   Click image for larger version
