Welcome to the Mk2 headache..No just joking..Pretty much everything from the 5MGE and 6MGE are identicle except the crank and timing gear..If the car hasnt been tened to on a regular basis you might start your prevenitive maint. ..Like thermostat,fan clutch,flush and burp cooling system..If it continues to over heat try the IAC valve,Then if it continues you might have a cracked head or leaking head gasket..Keep us posted and good luck..
