Originally Posted by Bru
It's like you said: heater hose area. I believe I've seen this at the very back of the head in the valley holding a hose. The hex retaining plug for the valley plate, behind spark plug number 6, is threaded in the center. I have a GTE so I can't be more specific other than remembering photos I've seen or parts yard flashbacks.
Thank you! That's exactly where it goes. Now I remember, replaced that hose with non-formed and the bracket doesn't fit. Should probably get the correct hose.
On a side note: Fixed the EGR cooler cover to block leak with JB Weld and it has held so far for a couple hundred miles.
