your heater problem is a broken valve that can be by-passed . i forget the details right now . the valve is passenger side (U.S) on the firewall it's one little swap of tubes and you'll get heat . research online you'll find it.
it's a vac switch and with no switch there's no hot water flowing into the heater core
