Old 10-29-2005, 07:43 AM   #2
mrnickleye
mrnickleye's Avatar
Without being there, its difficult to help. The timing (belt) must be perfectly set. The distributor must be set in the correct tooth. Everything else should be plugged in, and hooked up correctly.
I would go top to bottom, left to right. Make sure as best you can before trying again. You can damage things when it backfires.
