ive gotten my mk3 to drift pretty successfully on 90 degree turns as well as smooth curves...it takes a lot more skill than a normal 240 or an rx7 because of its weight but it can be done, once ur able to drift an mk3...a 240 or an rx7 is pretty easy because it is balanced better weight wise, an mk3 takes a lot of practice and you will get frustrated, in wet weather its easy, but in dry it takes a lot more patience
Now: Saving for an MKIV
Broken Rides:
