Originally Posted by Burn N' Up
...3" Down Pipe from Suprasport.com.... And then of course either no cat or a 3" high flow cat...
All aftermarket downpipes I have seen eliminate the cat.
There is a current thread recommending how money should be initially spent when starting with a MkIII. liek you know liek I don't mean to be an a hole but liek you can read liek these threads liek you know.
http://www.toyota-supra.info/forums/...ead.php?t=2312
By the way, what happened to the sheared bolts on the differential and crossmember that you posted about a while back?
