Old 11-04-2005, 06:09 PM   #11
SupraMan1784
SP58GT
no, injectors just spray the amount of fuel needed into teh combustion chamber, theyre controlled by a solenoid which is pretty much controlled by the ecu...without going through all the sensors and whatnot, upgrading injectors gives you more capacity...meaning it has the ability to spray more fuel in teh to chamber and you max it out as easily...it has a higher limit
Now: Saving for an MKIV
Broken Rides:
