Originally Posted by SupraMan1784
7mge to a 7mgte is pretty much a direct bolt-on...theres no major electrical work you will have to do...though you might want to get a boost meter now that you have a turbo, teh harnesses are exactly the same...as for the computer...i think u might have to switch them..though i never made this swap it would make sense to since now you have boost...though with a piggyback or a standalone im sure you can tune the na ecu into accepting boost and yes..the na tranny does bolt-on to the turbo motor...both are 5 speeds and are the same...unless you are doing an auto to manny conversion then itll be different obviously
the harness between the 2 are not the same, the turbo harness has a few more sensors integrated into it, turbo boost, temp, etc. alot of the sensors have different connectors because of the different parameter of the sensors, differentiating them from the turbo sensor and N/a sensor. the ecu cannot be made to except the turbo boost, different chipset, the ignitor is different, the 2 manual trannys will bolt up but are not the same, the N/a tranny is very weak and synchro's are different and will tear up real quick if you do any speed shifting, which with a turbo ppl tend to do alot. Suggestion, get the harness and ecu and ignitor with the engine your getting. if not, you can get ecu's and harness's on ebay really cheap.
