Old 11-06-2005, 06:02 PM   #10
joel w
joel w's Avatar
im not really pissed, now! i just didnt like when you said it was not even worth mentioning it here. if me spending coin on useless items helps someone else to save then its totally worth mentioning it whether im right or wrong.. and i did all the work myself. porting and polishing and so im only into it the cost of my time. as for the dual actuator it was 100 but allows me to adjust boost in the cab without a bleeder valve. yes you do make sense i do thank you for your info. i thought about getting a header, but ive heard that they crack to easy and that the gains where minimal without a larger downpipe. so like i said i got to start somewhere... what kind and where did you get yours? are you in the www.7mpower.com top 10? you should be with that hp
