The clutch fan is on the very front of the engine, its the big plastic fan! its real easy to remove, just four nuts and its gone, the fan shroud should be removed also. you'll need to put the nuts back on to hold the pully on but you'll need some washers before the nuts.
make sure if you remove the fan that you buy an electrical fan right away so you wont over heat.
good luck!
