Hi,
Have recently acquired a Mk3 Supra Turbo (7MGTE w/ CT26 turbo, no mods). Engine seems to run OK, no smoke, no overheat, 40psi oil pressure, but turbo boost only running 0.5-1 psi. Pickup is terrible (0-60 maybe 15ish seconds), and top-end of around 90mph [would this be normal if the turbo shaft was broken?]. Auto box seems to be kicking up/down OK though.
Firstly, anyone have any suggestions as to what I might want to look at first? Secondly, if the turbo itself is faulty, how easy are they to swap over? I've already checked the diagnostics - no errors, and removed the inlet hose and checked that the inlet rotor spins freely, no noticeable splits in hoses, but sounds like maybe it is venting pressure somewhere :S
TIA
Tony
