Originally Posted by Isphius
If i fill it, its fine. when it runs, it pumps it all out in about 20 mins. im replacing the whole motor anyway cause iy has a wicked rod knock, probably from the overheating problem (the last owner was pretty...idiotic). But this believs me to think its a pretty big leak....and its above the radiator somewhere and it has to be pressurized to come out. i already disconnected the heater core and it still leaks.
There is a block off nipple on the back of the head that usually leaks, or it could be the egr cooler, both are culprits to leaking.
