Old 11-10-2005, 11:17 PM   #4
RyDeFly
RyDeFly is on a distinguished road
Another message from the seller:
"I only had the head gasket and block replaced. The mechanics thought that
the head was fine. I don't know if they used new bolts or if they only
tightened them to given specs. It has only overheated once since the
repairs and that was after 7 hours on the interstate and going over a
mountain pass. However, I have not had it on any trips longer than about
2hrs since."
Do supras have a tendency to overheat like that, esp. with turbo? Or would that overheating be another HG issue? I'm guessing seller's mechanic only torqued gasket bolts down to 58ft-lbs., so if i buy this one, would it be a good idea to get HG done all over again?
Thanks for the input
RyDeFly is offline   Reply With Quote
