trim by the way...
i think trim is just the size of the intake wheel diameter? mine was upgraded to 50 trim and the housing was machined to fit the larger wheel..and nothing was done to the exhaust side. i guess the exhaust side mods are not needed untill higher boost levels. 50 trim is good to about 400 hp or 15psi (the sweet spot of the turbo) where it runs most efficiently....bigger hp motors need more air and or lager wheel to flow more air..
