i just put a new aftermarket fuel pressure reg in
i would start with what he said but i did some research on the pressure thing and it could very well be as simple as a vacuum leak with your reg it should atleast run bewteen 28 psi and 34psi i ve had to up my pressure but i do know at stock they run where i said i m running at 38 psi now wow what a big diffrence so after checking your pump i would move to the regulator next let me know if that is what it is if it is the reg i have one in good shape that i could sell u for cheap
