Originally Posted by SupraMan1784
you could drop in a jdm engine...it doesnt matter if the car is rhd if im correct, the motor mounts in teh same place as teh usdm...so whether u get a jdm or usdm motor it will still be a straight up bolt on
LIKE I SAID BEFORE HERE IS EVERYTHING YOU WILL NEED TO DO A GOOD SWAP
http://www.mkivsoopra.com/project
you might wanna look into getting a USDM engine.. (correct me if i'm wrong )
but you get
bigger injector
cams
bigger or better turbos , I forgot... ( jdm are ceramic usdm are steel )
and something else i forgot
can someone fill in the gaps???
