Old 11-19-2005, 12:30 AM   #2
mrnickleye
mrnickleye's Avatar
Unhappy
When you press the clutch pedal all the way down, you have basically dis-connected the transmission from the engine.
The input shaft bearing in the trans might be going bad.
Very rare, but the throw out bearing may be barely touching the pressure plate when the pedal is not being pressed.. Try and press the clutch pedal a tiny bit, just a little tension on it, and see if the clicking stops.
