Old 11-21-2005, 03:32 PM   #1
Burn N' Up
Burn N' Up's Avatar
I'm in the same boat, except i replaced that vacuum valve on the passengers firewall also... only mine still doesn't work. I can hear the motors moving in the fire wall but no heat. Is there a seperate fan that blows in conjunction with the main ventilation fan to push heat into the mix? Something is still jacked.
