remove the door panel
yes you will need to remove the door panel. there are screws around the door.i dont remember how many but there are two under the circular pop out things on the door handle, and two under the triangular speaker grill. once the door panel is off the speaker will be in the speaker box which you will need to also unscrew to get out.
