Not that this helps you now, but it might be helpful to others reading the post or yourself in the future. When I took my GM TPI motor apart I labeled every wire & hose and the corresponding connections, and made notes along the way. This takes a bit longer but you'll more than make up the time at reassembly. I also took digital pics before starting to note locations of wires, brackets, accessories, belt routing, etc. My GTA is pre-serpentine and has four separate belts, and I can attest that the brackets & accessories will mount up incorrectly... I'll take pics at any point where I look at it and think "this'll be a pain to get back together right", and after other parts are out of the way to get a clearer pic.
