Thread: High miles...
Old 11-24-2005, 10:32 PM   #2
Burn N' Up
Burn N' Up's Avatar
Here is a tip you can apply to any car. No problems? Don't make them! Anytime you crack the block your asking for trouble unless your expierenced. Instead give it, or have it given, a through inspection of all the bolts, brackets, mounts, hoses, belts, etc. Find whats broken, then fix. Also, don't forget to do the basics. Flush your brake and clutch(if applicable). change tranny oil or fluid. Oil change, Fuel/oil/air filter change. Check tire tread/condition. replace disposable items like plugs and wires. That kinda stuff, welcome to the Supras, they are alot of fun and rewarding if you put the time and work in. Just remember: 1)Repair, 2)Restore, 3)Research, 4)Retrofit and 5)let it rip.
