thanks for the reply.....no it doesn't jutter, it's clutch slip, from trying to give it to much out of the hole i have been playing with it to see, such as, down gearing from third to second, and punching it around 90 degree corners to see if i can get it to power slide...i figure it's going to slip there if the disc is worn,it doesn't, but im still going to upgrade it, the car would perform so much better from a stop...i just noobed the clutch and burned the disc a little bit...shit happens
